Im trying to test a battery module with the EV2400 and the bq28z620R. Both devices are updated to the latest FW. The set up is supposed to test qOCV charge and discharge cycles. The battery is conneced thorugh the BMS to a power load and supply. Everything works fine, until some hours later the communication starts failing and I get the error message "Not able to find a free communications adapter." It has happen during charge and discharge, after long hours and after short ones. I cannot see what the root of the issue could be and would be very thankful for further assistence.
