Hi Expert,
My customer is using the TPS1HC100-Q1 in their project. What's more, there is an block diode connected to battery. You can see the block diagram below. What's more, the load is inductive.
Should we still need the Rgnd+Doide as below?
From my perspective, for inductive load, we still need the Rgnd+diode even though we have the Battery block diode.
When we disconnect the inductive load, the output voltage will go negative which may damage the device. We have the Vclamp. What's more, we need the Rgnd to get coneected to GND and a diode to keep the GND voltage.
- Do we need the Rgnd+ diode when there is an block diode on battery? Why?
Thanks a lot for your strong help!
Kind Regards
Imelda
