PCB copper area w.r.t charac params
Hi.. i had a doubt related to TPS series IC..
To decide the PCB Copper area for a given IC, we need to check the characterization parametres psi(jb), psi(jt) .. rather than theta(ja)..
 (ref. to datasheet http://www.ti.com/lit/ds/symlink/tps73525.pdf    pages 12 and 13     and     http://www.ti.com/lit/an/sbva025/sbva025.pdf   page 10 )
AM I r8 ??
at a given junction temp (say 70 deg C) we need to know the power dissipation hence the above params as to how they change with temp.
So we need a graph of junction temp versus Power disspaton, as due to Power dissiaption, the Tj rises
Am I r8??
hence charac params change??
AM I r8??
Thus we need a graph that will give the variation of charac. params with temp or with power dissipation?
AM I r8??
hence to maintain a rated characterisation parametre... we need to know.. the PCB copper area required to dissipate the heat...
AM I r8??
Also the variation of PCB copper area w.r.t charac params??
Am i r8??
I hope the ques. is understood
Thank you
Smita
