TPS7A20: TPS7A2025PYCJR Performance problem
Part Number: TPS7A20
Hi
We put 5pcs on the board of this product, and after a long time accelerated aging test (power 60℃ 85%RH 720Hr), the test is normal. However, after being stored at high temperature and humidity for a period of time (80℃ 85%RH 96Hr), it was found that the test of 1pcs was abnormal, and no voltage output was found by testing the power chip with a multimeter
Could you please help confirm the cause
Thank you.
