TPS7B81: Check the ground pin current with 10uA load for TPS7B81
Part Number: TPS7B81
Other Parts Discussed in Thread: TPS709
Hi Team,
Could you please kindly help to check for TPS7B81 with 24.5V input voltage, and 3.3V output voltage, En pin pull high, and connect to a 10uA load, then, what is the actual current for below Iin?
Since for customer system they have requirement the Iin should satisfy Iin<10uA+2.5uA, could you please kindly help to check if TPS7B81 could satisfy customer requirement? If this device coudn't satisfy customer requirement, then, if there has any other device could satisfy this requirement? Thanks a lot for your support.
Best regards
Jie
