TPS54KB20: Footprint Symbol
Part Number: TPS54KB20
Hi expert,
Customer is requesting TPS54KB20 CAD file in .dxl(unit:mm). We download from product folder but it turns out nothing.
Could you please help clarify what might goes wrong?
Allan
  • Hi Allan,
    I was able to download and open the DXF file using Visio, since I don't have Autodesk. However, if you're having trouble opening the file, it might be because you're not extracting the zip files before opening. To fix this issue, please right click on the zip folder and select 'Extract All...'. This should allow you to open the file without any problems.
    Thank you,
    Tomoya
