hi
The TL431AIDBZR circuit is shown below, with a designed output of 5V and an actual output of 2.6V. Please help analyze the cause and determine if there is an issue with the resistor configuration?
Thanks!
hi
Thanks!
The 1.1uF load capacitance is in the unstable region of this device. This might be affecting the output voltage. Please remove or modify the capacitance values to be outside of the B curve. The resistor values should be fine.
Walter
hello,
Customer feedback: C82 and C83 are not soldered, only resistors, with an output voltage of 2.6V. Please help analyze if there are any other reasons? thanks!
What is the load current draw on the VR5V rail? The device may not be receiving enough current.
Walter
Under no-load condition, the output voltage is 2.6V.
Is there any other possible reason?
The input is a steady 12V? Have you tried swapping other TL431 parts?
Walter
