I am using this IC for my BMS and found an uncertain behavior at -20 deg.C. When I am using my BMS at -20deg. C I see a jump in my NTC from -20deg. to -6degC when I change my supply voltage from 48V to 42V.
Hi Smit,
A few things:
Max Verboncoeur
I am seeing this behavior across only one thermistor, i.e. used in as a 4th NTC channel in my BMS,
but according to my IC it is TS1,
the Waveform is
when i change my supply voltage from 48 to 42 V abruptly it fluctuates from 2.93V to 2.77V
GND 2 is my AFE's VSS
Hi Smit,
Could you share the full schematic of the AFE and its connected circuitry?
If you wish to share it privately, you are able to through E2E direct messages.
Max Verboncoeur
Hi Smit,
I've sent you a friend request on E2E. After accepting, you will be able to send the schematic to me privately through the E2E direct messages.
Max Verboncoeur
