Hello ti Expert!
Some Protections I might like to ask some protections when using bq76952. During the initial power-on, my pre-discharge set 1s timeout. During the initial power-on, the pre-discharge performance of the device was normal, but when the device entered shutdown, I used TS2 to wake up, and reconfigured the register immediately after the wake up (the same as the initial power-on). However, when I opened CHGFET and DSGFET at this time, the device showed that only CHGFET was opened, and DSGFET remained closed at this time. I would like to ask how this situation happened. Is it because it takes a long time for the shutdown to work properly after normal?
Looking forward to your reply.
thanks.
