Other Parts Discussed in Thread: USB-TO-GPIO2,
Hi team,
We have a 6+0 phase design based on the TPS53681. We can program the board fine using the Fusion designer software and USB-TO-GPIO2 adapter. We've exported the factory programming scripts from the software, and are trying to program the device in our manufacturing environment using our own I2C programmer.
Our I2C programmer can do the block writes and reads successfully, ie when doing a block read we get the data expected back so all looks OK. (Same applies to byte/word writes/reads etc). However after issuing the STORE_DEFAULT_ALL command (and waiting 1s), when we read back the MFR_SERIAL checksum, the bytes are different. The script expects 0x480125B9 and the device returns 0x484D2979. This is repeatable across multiple attempts on multiple blank devices.. If we run a board through NVM programming process on the GUI, and then transfer to our mfr test setup, the script executes successfully but that doesn't help us...
I've attached the Fusion design project file, and also the "factory script" the software exports, both in XML and CSV formats. Any advice on how to proceed would be great appreciated.
Regards, Peter
TPS53681 0.0 Address 88 Project File.xml
<?xml version="1.0" encoding="utf-8"?> <FactoryScript xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" FactoryScriptVersion="7.1.0" Cancellable="true" PEC="false" Required_Num_Devices="1"> <factoryDeviceScripts> <FactoryDeviceScript Part_ID="TPS53681" Match_Any_Address="false" Address="88" Description=""> <Task_Groups> <FactoryTaskGroup Name="Import USER_DATA"> <Tasks> <FactoryTask Task_Attribute_Name="Read_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.1" Reason_For_Last_Update="If program mode is false, meaning ROM mode you have the option to skip if the task is run and the device was in Program mode" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">173</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="expected_hex_value"> <Value xsi:type="xsd:string">0x81</Value> <Description>expected block in hex: Supported formats include "0F - DE", "0FDE", "0F DE", "0x0fDE", and "Fh". Partial bytes are supported. For example, 0xa (0A) or A0F (0A0F).</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="skip_if_device_not_in_rom_mode"> <Value xsi:type="xsd:boolean">false</Value> <Description>if this "read" is for ROM mode and the device is Program mode the task will be skipped</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Byte" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.0" Reason_For_Last_Update="writes a byte" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">0</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="data"> <Value xsi:type="xsd:unsignedByte">0</Value> <Description>byte data to be sent</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">176</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">CC0002002012</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">177</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">000000000040</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">178</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">760F00000010</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">179</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">0400110300C0</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">180</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">8F8FC777C73F</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">181</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">6488067F33FF</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">182</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">254A1414E87F</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">183</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">806D00002BFF</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">184</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">0002000000B3</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">185</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">000160808080</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">186</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">00662E40408C</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">187</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">0060200020E1</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a block" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">188</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">40D00F00FF01</Value> <Description>bytes data to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Byte" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.0" Reason_For_Last_Update="writes a byte" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">0</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="data"> <Value xsi:type="xsd:unsignedByte">0</Value> <Description>byte data to be sent</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Word" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a word" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">36</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">0x008D</Value> <Description>word data (for example 0x0A0F) to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Byte" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.0" Reason_For_Last_Update="writes a byte" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">0</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="data"> <Value xsi:type="xsd:unsignedByte">1</Value> <Description>byte data to be sent</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Word" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="Assumes SAA Adapter." Version="1.0.0" Reason_For_Last_Update="writes a word" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">36</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="hex_data"> <Value xsi:type="xsd:string">0x00FF</Value> <Description>word data (for example 0x0A0F) to be sent in hex format</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Byte" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.0" Reason_For_Last_Update="writes a byte" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">0</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="data"> <Value xsi:type="xsd:unsignedByte">0</Value> <Description>byte data to be sent</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Write_Byte" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.0" Reason_For_Last_Update="writes a byte" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">216</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="data"> <Value xsi:type="xsd:unsignedByte">1</Value> <Description>byte data to be sent</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Send_Byte" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.0" Reason_For_Last_Update="sends command byte" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">17</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Pause" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.0" Reason_For_Last_Update="" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="OTHER"> <Parameters> <FactoryTaskArgument Name="pause_time_msec"> <Value xsi:type="xsd:int">1000</Value> <Description>number of milliseconds to pause for</Description> <Arg_Type>System.Int32</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Send_Byte" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.0" Reason_For_Last_Update="sends command byte" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">17</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Pause" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.0" Reason_For_Last_Update="" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="OTHER"> <Parameters> <FactoryTaskArgument Name="pause_time_msec"> <Value xsi:type="xsd:int">1000</Value> <Description>number of milliseconds to pause for</Description> <Arg_Type>System.Int32</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> <FactoryTask Task_Attribute_Name="Read_Block" description="" NameSpace="TIDP.Factory.TaskLibrary" classType="Manufacturing" Assembly="TIDP.Factory.TaskLibrary" dependencies="" Version="1.0.1" Reason_For_Last_Update="If program mode is false, meaning ROM mode you have the option to skip if the task is run and the device was in Program mode" Assembly_File_Version="7.0.0.3" Assembly_Version="7.0.0.3" Technical_Description="" Obsolete="false" TaskType="PMBUS"> <Parameters> <FactoryTaskArgument Name="cmd_byte"> <Value xsi:type="xsd:unsignedByte">158</Value> <Description>command byte</Description> <Arg_Type>System.Byte</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="expected_hex_value"> <Value xsi:type="xsd:string">0x480125B9</Value> <Description>expected block in hex: Supported formats include "0F - DE", "0FDE", "0F DE", "0x0fDE", and "Fh". Partial bytes are supported. For example, 0xa (0A) or A0F (0A0F).</Description> <Arg_Type>System.String</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="program_mode"> <Value xsi:type="xsd:boolean">true</Value> <Description>if rom mode set to false [Default: True]</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> <FactoryTaskArgument Name="skip_if_device_not_in_rom_mode"> <Value xsi:type="xsd:boolean">false</Value> <Description>if this "read" is for ROM mode and the device is Program mode the task will be skipped</Description> <Arg_Type>System.Boolean</Arg_Type> <Input_Type>NORMAL</Input_Type> </FactoryTaskArgument> </Parameters> </FactoryTask> </Tasks> </FactoryTaskGroup> </Task_Groups> </FactoryDeviceScript> </factoryDeviceScripts> <Devices_Info_List> <ab> <a>TPS53681</a> <b>88</b> </ab> </Devices_Info_List> </FactoryScript>
