I couldn't find the rising time and falling time for the mosfet used inside ic.
tr, tf missing for switching loss calculation.
These MOSFET parameters are not typically mentioned in the datasheet.
I would suggest taking the LM61495-Q1 EVM and measuring the Tr and Tf based on the configuration you want.
Note that Tr can change if you are using a RBOOT resistor which slows down the rising edge SW to help improve EMI.
Jimmy
