TPS54360B-Q1: Sink current thru diode
Part Number: TPS54360B-Q1
Hi team,.
Low side is diode in this device. Is it non-synchronous rectification, correct? Does the device sink current from SW pin into GND thru the diode when output capacitance is large?
Hayashi
  • Hello
    The small FET you see in the block diagram is only used to recharge the boot capacitor when operating at
    high duty cycles and/or when there is not enough inductor current to recharge the capacitor during normal
    operation.
    The device is non-synchronous and must have a Schottky diode connected between SW and ground for normal
    operation.
