TPS536C7: PMBus address & IBIS simulation
Part Number: TPS536C7
Dear TI Team:
I have no experience on large current power design with multi-phase controller, there are some items need your help.Thanks!
1. I saw there are some items talked about IBIS simulation about TPS536C7 on TI forums, Could you share what function or signal exactly should be done simulation about TPS536C7?
2. For PMBus address setting in datasheet, I want to double check with you.
e.g.,There is PMBus address B2h,C0h,C4h in datasheet, I convert to binary data and 7 bit address,Pls help check Am I right?
Best Regards
Lisa
