LMZ10501SILR
Material device marking: 0501 421A DG
device marking on DATESHEET: 0501 9811 DG
LMZ10501SILR
The difference between the two markings ( 0501 421A DG & 0501 9811 DG) is the middle part which defines the subcontractor AT&S substrate code.
The first part defines the device code, and since this matches there should not be any issue.
However, the datasheet should reflect this. I will check this internally and get back to you.
Febin
I think you are in touch with our Quality team already. Work is progressing. Datasheet will be updated soon.
Febin
This will take approx 3-4 weeks to reflect in the system. Please check the d/s after that. If there are changes, I will inform you here.
Febin
