Part Number: TPS23861
Other Parts Discussed in Thread: TIDA-010046
Hi team,
Could you please answer below questions?
1. Is it ok to change SEN1 resistor 22.1 ohm to 22ohm?
2. Is it ok to connect RJ45 and Xfmr as below?
3. Basically, PD device has two diode bridge as below, correct?
4. What does it mean by "extreme" here? What kind of situation?
TIDA-010046 uses 10MQ100NTRPBF. What is the expected environment to choose this?
5. Same as No.4, Could you please explain how to choose DPnB and DPnA?
Hayashi
