TPS61183: LED Driver
Part Number: TPS61183
Hi, I am working to drive LED strip with 12VDC power supply. During the operating load, input power becomes down to 11.2V and LEDs start flickering. I want to control this issue by adding TPS61183 and divide the LED strip into 6 separate parts. The digikey part number of LED strip is 289-ZFS-105000HD-12NW-ND.
Please advise, if I use the TPS61183 driver, it will keep the constant voltage at output if the input voltage drops to 11V?
Thank you,
FS
