Question about UCC27322-Q1
Other Parts Discussed in Thread: UCC27322-Q1
In my application, the ground pins of UCC27322-Q1 are connected to a negative DC offset; the reason why I do this is I need the positive to negative output swing voltage.
My question is how should I connect the power PAD, should I connect the power PAD to negative DC offset or to ground?
If I connect the power PAD to negative DC offset, should I make a plane for this power PAD?
Sincere thanks for your answer.
