in my system based on BQ40Z50, after a few charge-discharge cycles the charge rate increases exponentially and finally its stuck at 100%.
Scenario explanation:
1. battery connected to host and starts charging.
2. battery charges at normal rate.
3. now change the RSoC to different value and again allow to charge
4. repeat the step 3 with arbitrary values
Observation: with each iteration the charge rate increases and after a few iterations it stays at 100% and not change or stuck.
What would be the possible reason for this?
regards
Abhijith
