recommend PWM Converter supply
HI i need PWM Converter supply i will give input voltage -10 to +10 Voltage signal in between  any voltage i will give it should convert 28v signal output Please suggest IC part no also EVM Module
  • Hi Shivaraj,
    Thank you for reaching out. I think we don't have such solution that support negative input and positive input meanwhile. We can support negative input to positive output, but the input abs can not reach zero.
    May I know what is the application here and where the -10 to 10 input come from? Do you get any solution from other vendors?
    Mulin
  • Hi Shivaraj,
    We have not seen an update from you for four weeks, so I assume the issue is solved.
    I close this thread now. If there is still something open, please reply and the thread will get opened again.
    If you have any other question or of the thread has been locked, please open a new one.
    Clicking the Resolved Button also helps us to maintain this forum.
    Mulin
