UCC29002: UCC29002 application
Part Number: UCC29002
Hi Team,
May I know if a PSU module with the UC29002 Current share has a recommended method for factory using the VR correction voltage, either unloaded or fully loaded.
Thanks!
BRs,
Jamie
  • Hello Jamie,
    Thank you for your question about using the UCC29002 load-share controller.
    I am unfamiliar with the terms "VR correction voltage".  Can you please explain this, or rephrase your question in another way, please?
    Load-sharing accuracy is most important in the fully-loaded case, and less so at lighter and lighter loads.
    The sharing of unloaded (or nearly unloaded) PSUs will not be very accurate, but generally this is not a problem for most applications.
    Ulrich
