Hi
The customer design with BQ25798. When it is blocked or the sunlight is weak, the solar output power becomes smaller because the battery charging current set by the customer is very large, which causes the solar output voltage to be pulled down to the voltage limit point, thus turning off the charging function.
After turning off charging, the solar output recovers after a while and then turning on charging again. However, due to low power and high current, it will be pulled down again and charging is turned off. If you turn it on and off repeatedly in this way, they will hear a whistling sound. Is there any register can prevent BQ25798 from turning on and off repeatedly like this?
Attached the schematic
LP Gataway PAGE01 Charge IC.pdf
Waiting for your reply.
Star
