Hello, I'm currently using the TPS78533QWDRBRQ1 regulator and our CM wanted to use the TPS78533B as an alternate.
Looking at the datasheet both devices are the same except for the B version has the enable on a different pin.
both versions show the unused pin as NC, so I wanted to confirm that if I tie both pins together for the enable that there would not be a problem that I am not aware off.
