We are designing our custom board design featuring the TPS63031DSK regulator IC, In our schematic we connect the VIN pin[5th pin] with VINA pin[8th pin]. However, in your datasheet's typical application circuit, there is no connection between these pins, So there is no voltage supplied to the VINA pin.
Could you please confirm whether our circuit is acceptable or not?
Nitheesh
