Part Number: REF102
Dear Tech Support Team,
The customer received part#REF102BU and informed that the top marking is not matched with the datasheet.
The datasheet states the device marking should be "REF 102U B" but the received part showed "REF 102U K".
I found the same case but there is no answer. Could you please help to check and advise on the correct top markings? Thanks.
Dan Lee
