Part Number: LM73100EVM
When using the LM73100, is it a must to add output capacitance?
If Yes, what is the minimum value?
Thanks!
Thanks!
Hi Erez,
It is not required to use output capacitance - what output capacitance is used is usually dictated by downstream component requirements.
Patrick
Hi Patrick,
Thank you for your response!
Could you please tell me what is the natural output capacitance of the LM37100 component?
regards,
Erez
Hi Erez,
LM73100 has a very small inherent capacitance on its output pin, on the order of 1-100s pF. Is this a suitable range for you?
Patrick
Hi Patrick,
Yes, I think the capacitance is in a good range.
I will check other needed characteristics and this component may be a good candidate for my application.
With your permission i will ask for more information when I will need...
Thank you very much!
Erez
Hi Erez,
Great, glad to hear! Yes, if you have any more questions or requirements you need please let me know.
Patrick
