TPS2HCS10-Q1: PARALLEL_12 register
Part Number: TPS2HCS10-Q1
Hi team,
I would like to drive load by both CH1 and CH2 parallel together.
In this case, set PARALLEL_12 register to 1 and then need to set both CH1_ON and CH2_ON together?
Or setting one of CHx_ON register is enough to enable 2 channels in parallel?
I also would like to make sure that only setting PARALLEL_12 to 1 does not turn on CH1 nor CH2, correct?
regards,
