BQ25756: Some design questions about BQ25756...
Part Number: BQ25756
Other Parts Discussed in Thread: BQ25750
Hi Team,
I have some questions about the BQ25756, please help to comment.
Thanks.
1. How to set the battery cells? Using the voltage divider for Vfb, right?
2. Could BQ25756 support detecting the battery status, such as battery absence or over-discharge while power supply input?
3. If I only need one direction charing from AC to battery, may I remove Q3 and Q4?
4. Does BQ25756 support the power path function or not? It seems the charging current will share with system loading according to the datasheet circuit!
