Part Number: LMR38020
Other Parts Discussed in Thread: TPS3762
Two Tech question for motor drive application.
1. Negative Current
Customer would like to use a LMR38020 device to implement below functions.
48Vin converts to 24Vout with 200mS, and then converter to 12Vout for load. Below is waveform. There is a negative current happened during 24V to 12V transient as waveform below. Is this acceptable?
2. We consider to use a supervisor TPS3762 to implement 200ms delay as below diagram. is it ok? Or any suggestion? Thanks.
