I am programming a TPS544C25 power supply to +3.3V by setting the Vout Command to 3.3V. The output voltage is correct after programming (writing to hardware and storing the config to NVM); however, the output voltage changes to +4.2V after a power cycle.
Any ideas on what might cause this?
Thanks in advance.
