Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS54540B-Q1: Negative output topology with webench power designer.
Part Number: TPS54540B-Q1
Other Parts Discussed in Thread: TPS54540B
Is there a possibility to use, to customize and to simulate the TPS54540B for a negative output voltage in Webench Power Designer tools ?
This kind of topology :
It seems Webench does not propose this topology.
I thank you in advance for your answer.
Dominique
