Hi there,
I recently asked a question on the feasibility of using a relay instead of mosfets. I have now got a relay control circuit hooked up to the DDSG pin which will open/close the main relay like the DSG pin would normally do (in the case of mosfets) in an OCD / UV situation.
One problem with this setup is it will not function in an OCC / OV situation. Is there anyway to configure the BQ76952 via firmware to Set LOW the DSG pin (and also therefore the DDSG pin) in the case of an OCC / OV situation as well?
Thanks in advance for your help,
Steven
