Dear Team,
I am using TPS62160QDSGRQ1 in my board for generating 1.1V and 1.8V.
The schematic is given below. May I know your comments.
They needs to be enabled by a microcontroller. The microcontroller is working at 5V supply.
Microcontroller is FS32K148UJT0VLQT_LQFP_144L .
There is voltage divider created by 100K and 33R so when the signal from microcontroller is low the voltage at EN pin is 1.65mV and when signal from microcontroller is high the voltage at EN pin is nearly equal to 5V.
May I know your comments about my EN signal design.
HARI
