Hey,
I am currently implementing the BQ25185 in my design. The data sheet is not clear about Factory Mode, after long press on MR/TS the IC enter Factory Mode, ok. but how dose it leave it ?
The data sheet says on one part that its MR/TS job to wake up the IC but on other section it says that only VIN insertion will work, which one is true ?
Regarding the charge enable, if I want to consistently charge the battery when a valid VIN is present, can I just tie the CE pin to GND permanently ?
