Other Parts Discussed in Thread: TINA-TI,
Hello Texas Instruments Support Team,
I am Chauhan Mihir. I am working as an Embedded hardware engineer at Aimtron technology Pvt.ltd.
So, we developed one product for entertainment industry just before 2 years and since then unit/design is under Production. Furthermore, the unit is operated with external supply (By 9V supply OR 5V USB) and battery.
Therefore, Texas IC is being used for ORing of 9V and 5V supply as its function is mentioned in datasheet.
In the present time, this device is in production stage. We made multiple units of same in last 2 years. But we received 20 to 30% of production lot back because of the functional failure. So, we analysed that failure unit, and we have identified that the PN # TPS2121 is fail and battery is damage. After replacing that IC with fresh one IC, that unit is start working.
So, what will be issue behind this failure.
Here I am attaching schematic section of that part. Kindly reply to us as soon as possible as we can move forward in analysis and correct it.
Thanks, and regards,
Chauhan Mihir
