Hello.
I felt confused about how to test the output curent limitation of TPS76801QD.I connected the output pin to the ground or connected a small resistance to output pin, I was not able to attain the same value as the data book descriibed .The value I got was very small.
Whether my method is false? If so ,how can I measure the output current limitation?
Thank you for your answer.
