Hi team,
Could you explain the function of VBAT_OVP_MASK? What is the meaning of "INT", interrupt?
If I set VBAT_OVP_MASK=1, when VBAT OVP is triggered, will Charger stop charging?
Thanks and look forward to your reply!
Hi team,
HI Kailun,
The INT output generates a 128us pulse for any status charge or fault bit change in registers 0x1B-0x27. The intent is for the host processor to know that something has changed and investigate further. If certain status or fault changes are not a concern, the mask bits can prevent that status or fault bit change from generating an INT pulse.
Jeff
