Hi Team,
I'd like to ask you about the recommended ESR range of input and output capacitor. Using UA78M05QDCYRQ1 on the board, but there is no ESR range specification in the datasheet. So please check it and let me know.
Hi Team,
Hi Jeffrey,
You're right - I also can't find this information in the datasheet. I have reached out to our design team and will get a answer to you within 2 business days.
Kelsey
HI Kelsey,
Please let me know if you get a feedback from your design team.
Hi Jeffrey,
Thanks for your patience - our main design lead is out of office until next week, so I'm trying to reach someone else who might be able to access the ESR information. I'll be back with an update for you in 1 day.
Kelsey
Hi Jeffrey,
Thanks for your patience. I've reached out to two further contacts, so hopefully we'll have an answer within a day. Will keep you updated.
Kelsey
HI Kelsey,
I'm sorry to push you about this case. please check it again and let me know as soon as possible.
Hi Jeffrey,
I have pinged the team again and will continue pushing and update you ASAP with their response. Our design lead is back in office on Monday, so worst case, you can expect a response then. I am making every effort to get you a response as quickly as possible, though.
Kelsey
Hi Kelsey,
It takes so long time to check this ESR information. Please push your design lead again about it and let me know ASAP. I need your help. Thanks for your support.
Hi Jeffrey,
I understand your frustration; I have pinged him again and communicated the urgency. Apologies again for the delay.
Kelsey
Hi Jeffrey,
There is not an ESR requirement for UA78M05QDCYRQ1, so ceramic capacitors can be used if desired. Really appreciate your patience on my reply, I know it has taken longer than ideal to get you answer.
Kelsey
