Dear TI experts,
My customer started their new project with BQ40Z50-R2. Could you review the schematic and layout?
Chase
Dear TI experts,
Chase
Hi Chase,
Are you aware that some of the capacitors on the 40z50EVM are DNP? (SRN/SRP pins)
A second GND plane is needed on your schematic, reference the EVM schematic.
TS3/4 appear to have resistors not a thermistors.
The resistor on the PTC pin should be a PTC thermistor.
I recommend reviewing the EVM schematic and layout guidelines in the datasheet.
EVM schematic found here - bq40z50EVM Li-Ion Battery Pack Manager Evaluation Module (Rev. C)
datasheet for layout guidelines - BQ40Z50-R2 1-Series, 2-Series, 3-Series, and 4-Series Li-Ion Battery Pack Manager datasheet (Rev. C) (ti.com)
Evan
Dear Evan,
Thank you for your support, and hope you had a good day.
--> I will not insert 2 capacitors. (C5 and C6)
--> Customer's PCB have only 2 layers. Is it okay? or should we add more layers to make second GND plane?
--> I will directly connect TS3 and TS4 to GND. (Customer will use only 2 thermistors.)
--> I will change to NTC thermistor.
Please check the question above. Thanks.
Chase
Hi Chase,
Your customer will need a second gnd plane, on the EVM schematic linked above, there are 2 GNDs referenced, "GND" and "CHGGND", the gauge needs a separate GND plane from the rest of the components.
Remember to disable the thermistor pins in BQstudio.
the thermistor needs to be a PTC type.
Evan
Dear Evan,
I discussed about 2nd GND plane with my customer. They said that they have to setup with 2 layers because of BOM cost.
- What would be happen if we don't have CHGGND? (i.e. accuracy of gauge will be decreased, or something else..)
- Or, Is it okay to make CHGGND in either TOP or BOT layer separately?
Please check this issue. Thanks.
Chase
Hi Chase,
We recommend having 2 planes; however I have seen this done by isolating the 2 GNDs. I would reference the EVM layout and schematic.
Evan
