Hello Team
Our Customer Minda requested Pspice Model with PG Pin for TPS7B8650DQDDARQ1
ca you please support and share the Pspice Model
thank you
Best Regards
Umesh Aghadate
Hello Team
thank you
Best Regards
Umesh Aghadate
hello Nick
Thank you for your reply.
Customer want this model with PG because, they want to understand the device and PG behavior when Vout short to BAT (Vin 13.5V)
we know Vout short to GND condition as mention in datasheet, it will hit ICL and thermal shutdown triggered,
can you please explain what happen in short to bat condition
Best Regards
Umesh Aghadate
Hi Umesh,
Is the LDO off-battery so that VIN = VBAT? I can check, but I expect the PG to be pulled low once the output is forced above its set point but I don't know at what voltage it will be pulled low.
Nick
