Hi Team,
My customer is facing issue with the battery charger BQ25798EVM eval kit.
When they connect an external USB charger it draws ~200mA with no load or battery connected to VSYS.
The IC’s temperature appears to rise by approximately 20 degrees.
They also connected an external power supply to TP23 (VBUS) and it was also drawing ~200mA @5V with no load or battery attached.
Can you please let me know if there is anything they can try or should they attempt to replace the IC on the eval board?
