Hi Francis,
I see in datasheet "The internal offset of the device can be measured and compensated using the lower LSBs of the 10-bit CHxIADJDAC." I'd like to know how to measure the offset of one device and how to calculate the compensation.
I ask this because my customer found one specific 92520 IC has lower accuracy.
They set CHxIADJ to output 187mA. One 92520 output current is 164mA while the others output current is around 190mA. They did ABA test (put this 92520 to another PCB) and found the this follows specific IC.
Thanks!
