TPS650333-Q1: OTP info for TPS65033303RGERQ1
Part Number: TPS650333-Q1
Hello PMIC team,
need your help to confirm OTP programing for TPS65033303RGERQ1 samples sent to C2K SW team in India.
I am helping with debugging observed Q&A WD function issue.
WD function does not behave according to datasheet definition.
It is not possible to exit WD Long Window, and WD Long Window time-out event never occurs regardless of WD Long Window duration setting.
This could be OTP setting related that impacts WD function.
C2K SW team is currently using TPS65033303RGERQ1 with
  • RID Register:  56 (decimal)
  • PID Register: 243 (decimal)
 Please share the OTP programming info for this device, in particular its WD settings.
Thank you
  • Hi Samir,
      Please find attached for the NVM programming info for this device.
        "my_model": {
            "$refresh_interval": 1,
            "PID": 243,
            "RID": 56,
            "CONTROL_LOCK": 0,
            "BUCK_LDO_CTRL": 31,
            "GPIO_CTRL": 31,
            "CONFIG_LOCK": 0,
            "LDO_GPIO_CFG": 29,
            "BUCK1_VOUT": 16,
            "BUCK1_UVLO": 18,
            "BUCK2_VOUT": 29,
            "BUCK3_VOUT": 10,
            "LDO_VOUT": 18,
            "DISCHARGE_SETTING": 85,
            "SEQ_TRIG_BUCK1": 31,
            "SEQ_TRIG_BUCK2": 27,
            "SEQ_TRIG_BUCK3": 19,
            "SEQ_TRIG_LDO": 3,
            "SEQ_TRIG_nRSTOUT": 3,
            "SEQ_TRIG_GPIO": 127,
            "BUCK1_SEQ_DLY": 82,
            "BUCK2_SEQ_DLY": 66,
            "BUCK3_SEQ_DLY": 50,
            "LDO_SEQ_DLY": 34,
            "nRSTOUT_SEQ_DLY": 19,
            "GPIO_SEQ_DLY": 255,
            "INT_ACK": 0,
            "INT_ACK_BUCK1": 0,
            "INT_ACK_BUCK2": 0,
            "INT_ACK_BUCK3": 0,
            "INT_ACK_LDO": 0,
            "INT_MASK_BUCKx_LDO": 255,
            "FAULT_STATUS_BUCK1": 0,
            "FAULT_STATUS_BUCK2": 0,
            "FAULT_STATUS_BUCK3": 0,
            "FAULT_STATUS_LDO": 0,
            "VMON_BUCK1_CFG": 0,
            "VMON_BUCK2_CFG": 0,
            "VMON_BUCK3_CFG": 0,
            "VMON_LDO_CFG": 0,
            "ERR_BUCKx_LDO_CFG": 0,
            "RESTART_CMD": 0,
            "CFG_REG_CRC": 0,
            "DEV_STAT": 12,
            "DEV_ERR_ACK_1": 0,
            "DEV_ERR_ACK_2": 0,
            "DEV_FAULT_STATUS_1": 0,
            "DEV_FAULT_STATUS_2": 0,
            "INT_MASK_SAFETY": 3,
            "PIN_MON_ERR_CFG": 0,
            "ABIST_GROUP_DONE": 0,
            "ABIST_BUCK1_2_ACK": 0,
            "ABIST_LDO_BUCK3_ACK": 0,
            "ABIST_SYSTEM_ACK": 0,
            "ABIST_RUN_CMD": 0,
            "POWER_GOOD_STATUS": 0,
            "WD_ANSWER_REG": 0,
            "WD_QUESTION_ANSW_CNT": 48,
            "WD_WIN1_CFG": 127,
            "WD_WIN2_CFG": 127,
            "WD_LONGWIN_CFG": 8,
            "WD_MODE_REG": 0,
            "WD_QA_CFG": 10,
            "WD_ERR_STATUS": 0,
            "WD_THR_CFG": 255,
            "WD_FAIL_CNT_REG": 0,
            "EEPROM_PROG_CMD": 0,
            "VMON_EE_CFG": 63,
            "VMON_VREF_TRIM": 8,
            "VMON_UV_TRIM_0": 36,
            "VMON_UV_TRIM_1": 36,
            "VMON_OV_TRIM_0": 36,
            "VMON_OV_TRIM_1": 36,
            "VMON_OVP_TRIM_0": 18,
            "VMON_OVP_TRIM_1": 18,
            "TSD_GAIN_TRIM": 16,
            "TSD_OFFSET_TRIM": 16,
            "REFGEN2_VREF_TRIM": 47,
            "REFGEN2_BGTC_TRIM": 15,
            "REFGEN1_VREF_TRIM": 47,
            "REFGEN1_IREF_TRIM": 31,
            "REFGEN1_BGTC_TRIM": 15,
            "OSCMOD_TRIM": 64,
            "OSC4P5MHZ_TRIM": 64,
            "PMOSLDO_ILIM_TRIM": 8,
            "PMOSLDO_VOUT_HIGH_TRIM": 64,
            "PMOSLDO_VOUT_LOW_TRIM": 16,
            "BUCK1_ILIM_TRIM_0": 136,
            "BUCK1_ILIM_TRIM_1": 20,
            "BUCK1_SR_DT_TRIM": 5,
            "BUCK1_EE_CFG": 50,
            "BUCK1_ERRAMP_TRIM": 59,
            "BUCK1_RAMP_TRIM": 58,
            "BUCK2_ILIM_TRIM_0": 136,
            "BUCK2_ILIM_TRIM_1": 20,
            "BUCK2_SR_DT_TRIM": 0,
            "BUCK2_EE_CFG": 19,
            "BUCK2_ERRAMP_TRIM": 58,
            "BUCK2_RAMP_TRIM": 57,
            "BUCK3_ILIM_TRIM_0": 136,
            "BUCK3_ILIM_TRIM_1": 20,
            "BUCK3_SR_DT_TRIM": 0,
            "BUCK3_EE_CFG": 19,
            "BUCK3_ERRAMP_TRIM": 58,
            "BUCK3_RAMP_TRIM": 57,
            "EE_SPARE_REG_0": 16,
            "EE_SPARE_REG_1": 16,
            "TEST_MODE_ENABLE_0": 0,
            "TEST_MODE_ENABLE_1": 0,
            "BUCK1_TEST_0": 0,
            "BUCK1_TEST_1": 0,
            "BUCK2_TEST_0": 0,
            "BUCK2_TEST_1": 0,
            "BUCK3_TEST_0": 0,
            "BUCK3_TEST_1": 0,
            "BUCKX_TEST": 0,
            "LDO_TEST": 0,
            "REFGEN1_TEST": 0,
            "VSYSMON_TEST": 0,
            "NVMLDO_TEST": 0,
            "VMON_TEST": 0,
            "TSD_GNDLOSS_TEST": 0,
            "REFGEN2_TEST": 0,
            "OSC_TEST": 0,
            "EE_CFG_0": 21,
            "EE_CFG_1": 199,
            "EE_CFG_2": 224,
            "EE_CFG_3": 250,
            "EE_CFG_4": 223,
            "EE_CFG_5": 2,
            "EE_CFG_6": 8,
            "EE_CFG_7": 4,
            "EE_CFG_8": 6,
            "EE_CFG_9": 0,
            "EE_CFG_10": 0,
            "EE_CFG_11": 0,
            "EE_CFG_12": 0,
            "EE_CFG_13": 0,
            "EE_CFG_14": 0,
            "BUCK1_VOUT_TRIM_0": 16,
            "BUCK1_VOUT_TRIM_1": 16,
            "BUCK2_VOUT_TRIM_0": 16,
            "BUCK2_VOUT_TRIM_1": 16,
            "BUCK2_VOUT_TRIM_2": 16,
            "BUCK3_VOUT_TRIM_0": 16,
            "BUCK3_VOUT_TRIM_1": 16,
            "BUCK3_VOUT_TRIM_2": 16,
            "DFT_ACTIVATION": 0,
            "ATB_SEL": 0,
            "DTB_NRST_SEL": 0,
            "DTB_NINT_SEL": 0,
            "DTB_SEL_GPIO": 0,
            "DTB_SEL_SEQ": 0,
            "DFT_MUX_CTRL": 0,
            "DFT_FAULT_MASK_1": 0,
            "DFT_FAULT_MASK_2": 0,
            "DFT_BYPASS_CTRL": 0,
            "DFT_LOGIC_CTRL": 0,
            "DFT_FORCE_STATE": 0,
            "DFT_SSD_MOD_CTRL": 0,
            "DFT_TSD_CTRL": 0,
            "DFT_VMON_CTRL": 0,
            "DFT_INTBLK_CTRL": 0,
            "DFT_TFQ": 0,
            "EE_CFG_CMD": 0,
            "EE_FSM_CMD": 0,
            "EE_FORCE_CTRL_0": 0,
            "EE_FORCE_CTRL_1": 0,
            "EE_FORCE_CTRL_2": 0,
            "EE_WRITE_DIN_BYTE_3": 0,
            "EE_WRITE_DIN_BYTE_2": 0,
            "EE_WRITE_DIN_BYTE_1": 0,
            "EE_WRITE_DIN_BYTE_0": 0,
            "EE_READ_DOUT_BYTE_3": 0,
            "EE_READ_DOUT_BYTE_2": 0,
            "EE_READ_DOUT_BYTE_1": 0,
            "EE_READ_DOUT_BYTE_0": 0,
            "EE_CRC_GEN_0": 0,
            "EE_CRC_GEN_1": 0,
            "DFT_MVBUCK_SR_DT_RB": 0,
            "DFT_LVBK_DT_RB": 0,
            "DFT_OSC4P5MHZ_RB": 0,
            "DFT_OSCMOD_RB": 0,
            "CFG_CRC_GEN": 0,
            "BUCKx_MINTOFF_TRIM": 21,
            "BUCKx_SPARE_TRIM": 1
    Thanks!
    Phil
