BQ76952: Current sense shunt simulation test
Part Number: BQ76952
I want to ask how we can perform the current sense shunt simulation test for the IC BQ76952,
I have applier 1mV Btw sense+ & sense - , before that, it shows 10-20mA discharging current but after applying a voltage to pin it shows 350-400A discharging cuurent also i have measured the voltage diff btw them and it show 1.2-1.6V
I have used your typical application schematic refer in datasheet
  • Hello Hitesh,
    What is the voltage reading on the SRN/SRP pins? Where are you applying the voltage, is this being filtered? Is there any issue if you apply a known current through the board?
    The supply you use should ideally be very accurate and not noisy. Coulomb Counter gain/offset may be needed for best accuracy. 1-mV on a 1-mOhm sense resistor should indicate 1-A of current flowing on the resistor.
    For it to read 350-A (assuming 1-mOhm resistor), the voltage on the SRN/SRP pins would have to be ~350-mV. Which goes beyond our recommended voltage range for the shunt measurements.
    Do you have a schematic?
    Luis Hernandez Salomon
