FOR NTC of 4kohm (approx 45C) I need to shut off charge current to battery. how?
I would recommend placing a resistor in series and parallel to modify the threshold of your 10k thermistor going to 4k at 45C such that the TS voltage is below VTS-60°C at that time. This will require some theoretical iteration to meet your desired values. Please note this charger is designed for a single 10k thermistor with the ranges listed in the datasheet. Modifying one of these thresholds may affect the others.
Mike Emanuel
