Part Number: LP87523-Q1
Hello team,
In LP87523-Q1 IC have the Internal Roof and floor control, Could you please tell me what is that & what is the use of that
Hello team,
Hi Nagarjuna,
As the name suggests, this means that the output level eventually reaches a floor value when not enabled. The use case is up to your design for when you may need a secondary, lower level to supply other end devices/components that may desire an input when the higher level may be no longer or temporarily not needed.
Field
