I have a possible problem (the behavior is not the desired one for my application) with the restart of the IC. So the IC drives two Mosfets, the drive is as intended, it works perfectly. The issue appears once the PWM goes low. So the IC stops the drive, but when the PWM reappears, the drive doesn't start again. So my intended behavior would be for the IC to restart automatically when the PWM appears again. Can anybody give me any advice? Thank you.
