Brad,
we have met the customer with local TI support and analyzed the board.
The customer tried to design the isolated power supply based on UCD9248 and UCD8220 but failed to calculate the paramteres for digital control loop. This was so because this pair is not modelled in the Fusion digital power designer.
What he needs is to design a power supply with input 75-155 V AC/DC and output 50V DC 1-6A, 3 channels. This power supply has to come with monitoring (possibility to send log of Vin, Vout, Iout etc to MCU - locomotive safety system).
We have found that there is a solution based on UCD30k called TIFF (we could choose it from the dialog in Fusion power designer). Are we right that this solution fit the spec above? If yes, could you pls give us asap BOM and design docs for it. Also your recommendation to modify it are welcomed!
