TPS62860: TPS628600 , EN pin is open drain or not? I see in functional block diagram a open drain mosfet
Part Number: TPS62860
In TPS628600 datasheet I see the open drain mosfet at enable pin. but in description its not mentioned as open drain. so is it fine to connect external pull up or not. please clarify on this
