I'm using the TPS79928 fixed LDO which has 3.3v input and 1.8V enable signal. When the EN is low and input voltage reached 1.24V the output has a pulse of 0.54V and stays there untill enable is high. I want to know the reason for the unexpected output pulse when the EN is low ?
Please suggest some solution and reason behind it
