LMR54406: LMR54406 HIGH CURRENT
Part Number: LMR54406
i HHAVE 6 PROTO-TYPE OF THE ATTACHED CIRCUIT WITH LMR54406. EVEN WITHOUT LOAD INPUT CURRENT APPEARS HIGH (LIKE SHORT CIRCUIT). PLEASE HELP.  PLEASE EMAIL TO ME WING.LAM@DETECTORSINC.COM. Best Regards. Wing Lamlmr54406.pdf
  • Hi Wing,
    Thank you for designing with our products.  I took a look of your schematic and compared with our Datasheet pin assignment, I found your schematic's IC pin out is different from the datasheet, and it may explain why you see shorts.  See below.
    Please correct the pin out errors.
    Youhao
